Firat
Below is my current setup......
its a 2600k @ 4.7ghz and it is cooled by a 60 mm thick 360 rad, a 60mm thick 240mm rad and a thin 120mm rad (overkill i know!!!)
so thats 3 rads in total!
i also have a gtx 570 phantom on air all on a Z68-UD7 board.
Now the question is looking at my temps do you think i should watercool my chipset, 57c on the nf200 and 49 on Z68 seems high?
i will deffo watercool the GPU as ever since i oced it to 860 on core and 2000 on mem temps peak at 75-80c and even the phantom can sound bad at those temps!!!
These temps are after 18 hours of folding, so a little toasty
The looping will change as im not quite happy with it, can you uses any of the GPU waterblock threads as input/output or like the cpu blocks does it have a designated one?
Also do you think i will need a 2nd D5? do to the number of blocks and rad this rig could eventually have?
Thanks
Firat
Thanks
Firat
