maverik-sg1 said:
LOL
Sorry guys,
Not blowing me own trumpet (well actually I am I guess) most advice I supply is golden (showered with a splash of not so shiny stuff) and backed up with a lot of experience (trial and error) - If I take the time to help a brother out - I would expect them to use that help :spoko:
But accpeting your point that there are a lot of people here all giving reasonable levels of advice I should not have jumped in like I did - especially after having not had a good sleep last night - so I apologise for my conduct.
Mav
:bighug: It's alright Mav.
I do appreciate your help guy's and i owe you a big time
, the bigest restriction (to find the sweetest spots on my RAM) is shortage of time (i'm working in stupid company) as it takes a lot of time to do tests...
At the mo i'm trying find rock solid overclock for 24/7 use and looks like i found it:
CPU 2.6GHz x10 1.55V
RAM 260MHz 2.5-3-3-6 2.92V 1:1
At the mo SP2004 runing 12h 13m
looks fine.
Will do a couple another tests, but i think i'll use these settings when will selling PC 8).
But i still will do some benches for EP-UK team after bordy's 7800GTX's will arive. And then i can use CPU @ 2.8 or 2.85GHz with higher vcore and run RAM @ 285Mhz with loosen timings.
Anyway i'll still play around with RAM to get better speed, but as i said before, i wont go mad with geting last drop out of it, becouse my CPU isn't a best choise and i'm quite limited on it and i'm quite busy @ work and don't have enough time to spend @ PC doing tests
Mav, i will use this post as a good guide in the future and will try to get some BH-5 for my next rig and then we will have some fun
Thanks everyone who tried to help!!!
P.S. As i'm still will try tweek RAM a little bit, might ask some advice later on
Cheers
