I am attempting to paint the side panel of my old computer and cant get a straight answer from people. I have expience with painting but not getting a mirrior finsih.
so striaght to the question do you re apply a clear coat after every sanding session eg starting at 800grit
-800 grit
-re apply clear coat
-1200 grit
-2000 grit
- reapply clear coat
or do you just have one clear coat get it extremly smooth then rubber compound and buff?
-800 grit
-1200 grit
-2000 grit
