CalVic
Member
Heya everyone,
Looking at upgrading from a H100i as I've reached it's cooling ability with my AMD 8350. I've pieced together the following spec and I just wanted to make sure it's all good and will work nicely
Pump & Res: K-DDC 3.2 PWM X-RES 100 with EK-UNI D5 Holder
Radiator: Alphacool NexXxoS UT60 240mm or BlackICE SR1-240
CPU Block: Aqua Computer Culplex Kyros Delrin for AMD
Hose: XSPC 7/16" ID High Flex Tubing
Fittings: XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome)
The coolant I'll be going with is the Mayhems Pastel Ice White!
I'm open to suggestions and advice
Cheers
Callum
Cheers
Callum
