Wolfie1990
Hey guys this is going to be my first leap into water cooling im familiar with how its set up as i have been looking it up since like last year but basically i just need some advice of you guys here is my hardware:
I5 3570K
EVGA GTX 670 2GB
The rest is not imprtant i dont think but if you need to know just ask.
Now for the Kit ive put together here it is:
XSPC RayStorm 750 RS360 WaterCooling Kit
EK 670 Full Cover Waterblock - Nickel Plexi
XSPC RS240 120mm Radiator - Black
Mayhems Aurora - Tharsis Red Coolant 1L
XSPC 7/16" ID [16/11mm] High Flex Hose - Clear [1m Length]
OcUK 3/8" G1/4 - High Flow Style - Black Nickel - Compression Fitting x11
Corsair SP120 Quiet Series High Pressure Low Noise - Single Pack x7
i have added extra hose incase i need extra but my main question is will the hose fit the compression fittings and will the compression fittings fit the rads, pump/res, cpu block and vga block and also is what i have listed above good enough to cool my hardware?
Thanks in advance guys
I5 3570K
EVGA GTX 670 2GB
