CalVic
Member
Heya,
I installed this on Saturday, but not gotten round to actually posting pictures etc. To be fair, I'm a bit disappointed how it turned out, and I'm not entirely fully happy with how it looks. But I plan on adding a 280x waterblock and another rad to the loop so I'll make adjustments. I neglected to buy a 90 degree angle for the return line back to the pump/res that would have allowed me to loop it back over the motherboard tray without kinking. However the temps are certainly alot better than the H100i! With the same clock speed and voltage I was at 55c. Now with this setup I'm now at 44 - 45c under Pime95 and it's even quieter!
Kit:
Kyros Delrin Waterblock
NexXxos UT60 240mm Rad
EK 140 D5 XRES Pump/Res
G1/4 to 7/16 XSPC Fittings / 2x 45 Degree rotary fittings
7/16 XSPC Hose
Mayhems Ultra Pure H20
PC Spec:
AMD FX 8350 @ 4.8Ghz
Sabertooth 990FX R2.0
8GB RipJawsX
MSI AMD 280x [1180 Mhz Core / 1580 Mem Overclock]
Xonar D2X Soundcard
Thermaltake Toughpower 1200watt
Yes, I realise that side panel needs cleaning
Kit:
7/16 XSPC Hose
PC Spec:
8GB RipJawsX
Xonar D2X Soundcard
