clone38
Setup will be going in a corsair 900D review thanks to Tom
Asus Rampage IV Extreme X 79
Cpu 3820 @4.5ghz
Koolance RP-452X2 Dual 5.25 Rev 2.0
Koolance PMP-450 High Flow Pump : PMP-450
EK FB KIT RE4 CSQ Motherboard Waterblock Acetal
EVGA Hydro Copper Waterblock for GTX 680 Classified
Motherboard and cpu will have 90 Degree Rotary Fitting`s to cut down on the clutter.
3\8" ID - 5\8" OD Compression Fittings 45s/90s and normal ones.
Fans are Corsair SP120 Quiet Series Speed: 1450 RPM
I have some AFs for the front intake of the case and will have the corsair 140mm on the back.
Top roof rad Phobya G-Changer V2 360mm Triple Radiator : G-Changer 360 V2 Full Copper Fans in push
Bottom side Phobya G-Changer V2 480mm Quad Radiator : G-Changer 480 V2 Full Copper Fans in push
First question will one PMP-450 be ok or should I run two.
Second question I want to use clear hose any idea whats the best out there that will not Leach plasticizer into the loop ill be running Distilled Water,Monsoon Silver Bullet Antimicrobial G1/4 Plug and some sort of Concentrated Biocide.
Whats a good cpu bloke to run these days with the 2011.
Think that's about it for now.
Thanks.
Cpu 3820 @4.5ghz
Thanks.
