My Antec 900 is water-cooled -- I'm using a PA120.3 and hanging it off the back of the system using the Swiftech Rad-Box:
http://www.swiftnets.com/products/MCB-120-R2.asp
I basically mounted the PA120.3 from the middle fan mount ( I originally tried doing it from the top but found my Rad was taller than the box from that mount point). A use 3 Ultra Kaze 2000's mounted on the back in a pull config.
Since I don't have an image on hand I'll describe the setup.
A) First, on the back of the system where the metal butts up to the plastic top cover (where the 200mm fan is) I drilled 2x 7/8" holes and put rubber grommets in them. This is where the tubing goes in and out of the system.
B) From the radiator I go straight to my Apogee GT CPU block, from there to my NB Chipset cooler, then to my 8800GTX board, from there the GTX dumps into my MICRORES,
C) The Microres is mounted right on/above my PSU using the rear 'screen' above the PSU to mount the microres with the barbs pointing to the front of the system. The microres outlet connects to the MC655 pump inlet.
D) The pump is mounted on the bottom of the case by removing the lower drive cage. I wasn't using the space, I mounted my drives up on the upper one. The pump faces towards the back of the computer so the outlet of the microres and inlet of the pump face each other.
E) Pump outlet loops back up to the top into the Radiator again.
For me, it all fits nicely, I did some other case modifcations to route wiring to the back panel.
P-
