diablo1105
Hey all,
Going to be doing my first WC build in the Phanteks Evolv ITX. I have been able to get the majority of my gear 2nd hand in Aus thanks to another forum.
The components so far are:
XSPC 240 rad - 30mm thickness
EK Supremacy EVO
EK GTX980 TF5 GPU block + backplate
XSPC Clear concentrate coolant
3/8 ID 5/8 OD Red Tubing
10 Compression Fitting to match the 3/8 ID 5/8 OD Tubing.
My only question remains for the pump and res combo.
I have been considering either going a separate pump and res, however I'd like to keep it all in 1 unit.
I noticed a FrozenQ Micro-Res that features a D5 Pump mounting point at a local retailer (Umart) for about AU$60.
Would this be the better solution to go for over an EK 110 D5 PWM solution?
D.
EK Supremacy EVO
D.
