radioactivetux
Hi all!
I am soon to purchase a new computer after years of saving. It's primary purpose is going to be gaming, but I am studying a Level 3 BTEC Extended Diploma in Computing and AS Mathematics at college (UK) and we are working with virtual machines to set up and protect networks and some minor video editing/rendering. I am also studying for the Cisco CCNA and CCLI and hope to go into cyberspace security.
I have designed this computer from my own experience with designing computer for multiple purposes to fit a certain budget; but one think which I have no experience in is water cooling. Therefor I have put together a list of components to which i believe will fill my purpose.
I ask only one thing, I accept all forms of criticism but there is a line between criticizing and being an d**k.
PCPartpicker Link
or
Intel Core i7-4770K 3.5GHz Quad-Core Processo
Asus SABERTOOTH Z97 MARK2 ATX LGA1150 Motherboard
Corsair Dominator Platinum 16GB (2 x 8GB) DDR3-1866 Memory
Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive
Gigabyte Radeon R9 290X 4GB WINDFORCE Video Card
Corsair 450D ATX Mid Tower Case
Corsair 860W 80+ Platinum Certified Fully-Modular ATX Power Supply
NoiseBlocker NB-eLoop B12-PS 58.1 CFM 120mm Fan
AlphaCool Nexxxos UT60 240mm Radiator
XSPC RX360 Black 360mm Radiator
EK-Supremacy Acetal/Nickel CPU Water Block
EK-FC R9-290x GPU Water Block
Monsoon (ID 3/8 OD 1/2) Compression Fittings (White)
MasterKleer 59199 PVC Tubing (3/8ID) 10ft (White)
EK-Ekoolant 1000mL (Clear)
EK-D5 X-RES TOP 140 CSQ Acetal Pump/Reservoir Combo
Watercooling components for those who do not wish to trawl through the PCPartpicker page:
7x Monsoon (ID 3/8 OD 1/2) Compression Fittings (White)
My Questions:
Q1. The obvious, will this work?
Q2. Will the AX860i be enough power to XFire a 290x, both with water cooling?
Q3. Will the pump be powerful enough to perform the previously mentioned?
Q4. As for the motherboard I intend on buying an armored version of the Sabertooth, whether I buy the first revision or they release an armor kit for it. Will I have enough room in my Corsair 450D for the 360mm radiator?
Q5. Does anyone object to my parts list? If so say what could be improved.
I do not wish to take up too much of your time with this and i appreciate all of those who comment's help.
One final thing is that I will be purchasing white individually sleeved cabling for my PSU. Can't go all out in a system without "dem cables".
With thanks,
Radioactivetux
-Oliver Legg
PCPartpicker Link
or
My Questions:
With thanks,
Radioactivetux
-Oliver Legg
