Hi guys,
I want to change the fans on my Haf X case, i will want to buy 2 x 200mm, 1 x 230mm and 1 x 140mm to replace the existing Coolermaster fans that came with the case.
I don't know what model fans come on the coolermaster case from factory. But i am concerned about looks and noise.
I have a bit of a theme going on with the Assassin board sitting inside, so black and green.
Can anybody recommend me some fans that they think are good, have good noise levels and look the part, i wouldn't mind if they have green lights on the fans either. Otherwise they are fine to be just black or green.
