Vista what to turn off/disable ?
Rastalovich
Going to be doing a bit of an experiment.
Following the replacment of my mobo, I`m going to install Vista 64bit Ultimate SP1 on the pc, and as an experiment, I`m going to install all the drivers, leave everything set as per install, comfortable clocking on the hardware - and record a bunch of benchmarkers.
Then, I propose to turn off whatever I can in Vista, without hampering the OS, and re-take the benchmarkers with the hardware at the same settings - and procede to clock stuff up and re-take.
The pc is going to be purely game based. The only internet access it wants is for gaming, firewall will be hardware, antivirus handled by another pc, so in that sense, apart from the benchmark apps, nothing extra will be installed. No email, no browsing, no utils (outside of eventual oc`ing and benching).
I`ll entertain tweaks, turn-offs/disables (only that advantage the running and not have a change of screwing the OS as a result) - not interested in Vista Managers or other apps u install to do things - and try to stay away from illegitimate hacks. Strictly speaking, I want to install to SP1 and no further KB - if any further gaming KB are required as a definate, I`ll install them as per the game requirement.
Not interested in how the desktop looks either, it can end up looking like w2k if there`s an advantage.
I know the basic stuff and some common stuff, but I`d rather some1 post the basic stuff they know of so I don`t miss anything - I`m open to all suggestions especially if backed up with linkage.
(don`t want the thread to evolve into a Whatever vS Vista vS XP vS Linux vS Mac - we`ve done that and we all have our reasons for doing what we do)
So, what to disable ..
Darn, I forgot to mention that. I previously used vlite to install Vista 32 on a pc, subsequently the service pack would not apply. I can`t 100% say that it`s because of this, but it seemed to be the trend when I tried it again.
So I`m starting off with a full install.
name='DavidT' said:
Here you go: http://www.blackviper.com/WinVista/servicecfg.htm
Follow that guide and your computer will be speedier than ever :)
Reps on principle tbh.
That guy has done masses of research and testing, going to save an arse-load of time.
Gonna go through his service shutdown, disable some things I`m already aware of and see if I can hunt down anything else.
Boy he covers alot of bases in there, SP1 too.
Chosen to just run SuperPI 32m calc, and 3dmark06 1.02 non web based (average of 5 or more runs) - as a comparison to the same system, that should be fine.
Had to change the power settings installed as standard to be fair to both sides, as power saving isn`t a good idea for this.
EDIT: obstacle no.1 3dmark06 1.02 non web based uses OpenAL32.. and it won`t run. Gonna have to use the web based one... and somehow use it again when I`ve removed IE`s hooks ?!?!
Install before any changes x9650@3.5g / 4g ram@790 / 8800gt @670/900
SuperPI 32M - 14m18.797s
3dmark06 SM3 - 5758 (av)
3dmark06 SM2 - 5486 (av)
3dmark06 CPU - 5052 (av)
3dmark06 TOT - 13822 (av)
Memory footprint: 915m/4096m : 946m after 8 hours of idle : resting @ 937m
Cinebench 10 64bit exe (run-all tests from launch, no prefs changes)
OpenGL Standard Bench CB 4848
Single CPU Render Test CB 4301
Multiple CPU Render Test CB 15312
I used that link, although I only went for the 'safe' option for now.
What else should I turn off? Ram/hdd usage seems pretty high!
I`m going with his `tweaked` one, seeing as I think his more aggresive one will be very much a stand alone pc.
It`s really the aim of the exercise, I`m going to go through these too:
http://www.blackviper.com/WinVista/supertweaks.htm
Seeing as 3 or 4 of them I already was going to do, I`ll go through his list.
Anything in addition I`ll make a nice list. Final result will hopefully produce a full-on guide to getting a smooth install for gaming.
I don't want to turn off all the features and services, but I know most are unnecessary.
I need my AV to function, my network to function, games to work. I want that backup image thing too. I like that 3d scroll thing too...
Asside from the above the rest can go.
What is that thing that constantly pops up?
Me: Move X file here.
Vista: 'do you want to do that?'
Me: Yes
Vista: 'click here to do it'
Me: Click. (mutters ffs.)
Vista: 'do you really want to do that because if you do you should click here, but I'm going to ignore the fact you just said yes and add some more clicks in for fun, OK?'
Me: You
ing piece of
just do what i say already. Click
Vista: OK, I'm going to do it.
Seriously, whoever thought that was a good idea needs castrating. It's like they took the worst part of your mother and ex girlfriends and worked it into vista's personality. An OS that nags and mothers you.
Other than that I like Vista. I'm sure auto-nag can be turned off? Please say yes! THe blackviper site is blocked at work...
I don`t know about auto-nag, but uac can be completely turned off, and there`s also a way to turn off that thing that fades your desktop to dark when a pop-up comes along.
Try doing a move of a folder with files in it that u know it`ll nag u about - after the nagging it leaves the empty folder behind. hehe
That's the one! UAC. I just googled it and there are various ways to turn it off :)
Cheers Rast.
I hear superfetch chews hardcore amounts of ram. I'd turn it off for your experiment, I might turn it off too... If I find, no, when I find some good links/tips I'll post them up in here
This thread interests me...
Vista is nice apart from being a ultra guzzler!
I turned UAC and the sidebar off within a week trying to cut down resource useage
Keep posting with any findings especially performance wise :D
Any other sensible benchmark to run to do a b4 and after comparison ?
Best be quick if u got a suggestion, I`m freakin working 2morrow, so I`ll probably plough through this as soon as I get home tonite.
Don`t want 3dmark05 and below. Some kind of desktop-performance-thingy ?
I leave my sidebar.. Whats the point in us forever increasing our ram if all were gonna do is use less and less?? I get it if its purely a performance machine and for benching and stuff but normal use leaving something like the sidebar on wouldn't harm.
Unless it just annoys you then yeah totally fair :)
Thing with the machine as I`m using it, it`ll just game - that`s it. If it`s something not in use, I`m losing it. ;)
On the one I use for web etc, I keep the sidebar on tbh. Fill it with junk :p
name='Mr. Smith' said:
Rast, Cinebench 10
kk
EDIT: Done the cine, doing the stripping now.
Yeah well like you say on your gaming machine that makes sense, but on an everyday computer I can't see the point in getting rid just to use less RAM. Some of the gadgets are quite good :D
I`ll keep this window open and edit as I go through the stages. (maybe some notes to self which might not make sense til l8r)
0. Set power options to full performance (already done)
1. Disable UAC
1a. Turned off security alerts (u find out why after 1.) 927m after reboot.
2. System Restore and Indexing Features (15k+ files down to 0) 866m after reboot. (jumped up to 919m after a few mins)
3. Windows Sidebar. 825m after reboot. (892m after a few mins)
4. Remove Remote Assistance and ensure Remote Desktop is disabled. 884m after reboot and settle (notice Free is going down at the rate of 5mb second, cache is filling up) 893 after several minutes Free is almost all used up, stopped at 515m.
.. no drivers to update ..
.. no systray stuff to remove .. (check for auzen/creative with hjt l8r)
5. Add/Remove programs (Windows Features)
-Games
-XPS Viewer
-Internet Printing
-Remote Differential Compression
-Tablet PC Optional Components
-Windows DFS Replication Service
-Windows Fax and Scan
-Windows Meeting Space
-Windows Ultimate Extras (921m @ Free 376m) (884 @ Free 409m)
7. Services (using BlackViper`s "tweaked" listing, doing it manually, although I noticve he has an excellent util that makes a reg file on the site)
Application Experience - disabled
Application Layer Gateway Service - disabled
Application Management - disabled
Certificate Propagation - disabled
DFS Replication - disabled ** couldn`t see this one **
Diagnostic Policy Service - disabled
Diagnostic Service Host - disabled
Diagnostic System Host - disabled
Distributed Link Tracking Client - disabled
Distributed Transaction Coordinator - disabled
Fax - disabled ** couldn`t see this one **
Function Discovery Provider Host- disabled
Function Discovery Resource Publication - disabled
Health Key and Certificate Management - disabled
Human Interface Device Access - disabled *didn`t apply this one for fear of G15*
IKE and AuthIP IPsec Keying Modules - disabled
Interactive Services Detection - disabled
Internet Connection Sharing (ICS) - disabled
IP Helper - disabled *didn`t apply this one for fear of IPv6 only functioning (no link to Linksys)*
IPsec Policy Agent - disabled
KtmRm for Distributed Transaction Coordinator - disabled
Link-Layer Topology Discovery Mapper - disabled *didn`t apply this scared of network*
Microsoft iSCSI Initiator Service - disabled
Netlogon - disabled *scared DNS stuff*
Network Access Protection Agent - disabled
Offline Files - disabled
Parental Controls - disabled
Peer Name Resolution Protocol - disabled
Peer Networking Grouping - disabled
Peer Networking Identity Manager - disabled
PnP-X IP Bus Enumerator - disabled **scared network device discovery**
PNRP Machine Name Publication Service - disabled
Portable Device Enumerator Service - disabled
Problem Reports and Solutions Control Panel Support - disabled
Quality Windows Audio Video Experience - disabled
ReadyBoost - disabled
Remote Registry - disabled
Secure Socket Tunneling Protocol Service - disabled *not applied - scared of IPv6 network*
Smart Card - disabled
Smart Card Removal Policy - disabled
SNMP Trap - disabled
Tablet PC Input Service - disabled
Terminal Services UserMode Port Redirector - disabled
Virtual Disk - disabled
WebClient - disabled
Windows CardSpace - disabled
Windows Connect Now - Config Registrar - disabled
Windows Error Reporting Service - disabled
Windows Image Acquisition (WIA) - disabled
Windows Media Center Receiver Service - disabled
Windows Media Center Scheduler Service - disabled
Windows Media Center Service Launcher - disabled
Windows Media Player Network Sharing Service - disabled
Windows Remote Management (WS-Management) - disabled
Windows Search - disabled
WinHTTP Web Proxy Auto-Discovery Service - disabled
(if it survives that I`ll take my hat off)
++Print Spooler - disabled
++Windows Defender - disabled (Turned this into Automatic cos it complains)
++Windows Update - disabled (Turn off before disabling service)
7a. Turn off Windows Firewall.(should be at top) 1.05G footprint from boot, settles down to 7xx after a while.
** note here, all the time from boot the pc is using about 2% cpu to cache stuff ** Can`t be the best time to run benchers or whatever during this.
After about 7 minutes the caching has settled down, 792m @ Free 660m
6. Aero (themes) - idiot forgot to do this.
6a. Visual Performance Options - best performance.
After 7:20m 828m @ Free 627m
8. Run HijackThis and took out the IE hooks, CTXFiHlp, and those services with no files (half know they`ll go back pointlessly)
8a. Foolishly and flippently took out the 2 welcomecenter & 2 sidebar startup things - we`ll see if I`m so stupid. Restart >.<
** Jeez it started ok lol. 1 line in my startup sequence which is Uguru (and of course those stoopid services with files missing that are everpresent) **
I`ll keep the above post for future editing. Pop in some benchers here b4 I end for the night, still some to do, but atlest the mostly BlackViper section can be evaluated.
Install after Black Viper etc x9650@3.5g / 4g ram@790 / 8800gt @670/900
SuperPI 32M - 14m16.093s
3dmark06 SM3 - 5751 (av)
3dmark06 SM2 - 5487 (av)
3dmark06 CPU - 5085 (av)
3dmark06 TOT - 13829 (av)
OpenGL Standard Bench CB 4753
Single CPU Render Test CB 4347
Multiple CPU Render Test CB 15460
Memory footprint: 818m/4096m : Free 616m (2846m cached) after 7 minutes.
Kernel Memory: Total 201m, Paged 136m, Unpaged 65m
System: Handles 7423, Threads 400, Processes 30 (inc Taskmanager x2), Page File 750m/8362m.
Very minimal differences in the benchmarkers imo. 1 thing I will say tho is the scene changes in the 3dmark app zipped by.
I`ll delve into more stripping 2morrow.
