VGA Heatsinks
equilibrium
Hi guys, What vga sinks are compatible with the maze 4 blocks either low profile or non? I know the ocz are but are the zalman or any other? With the ocz i had to bend the fins slightly to fit one under the barbs which isnt a problem. Any help would be appreciated :) Thx all
Dave
hx Mav.
are they that much better? As the zalman ones are cheaper and i was wondering if it was works paying nearly double the price? Thx again m8
DAve
The Zalmans are only aluminium, where as the OCZ's are copper with more fins :)
Well worth checking the new Swiftech ones out, MC-14 I think they are called of the top.
Thanks master G may look into those!! If not looks like ill end up with the ocz again as they were easy to fit and didnt have to be cut. Cheers again m8
DAve
