g0ggles1994
Active member
In a break from usual PC Building, I have decided to dive into the Raspberry PI Pool.
Before I begin I'd like to pass this warning:
This project involves a CRT (Cathode-Ray-Tube) TV which carries a High Voltage warning (Which can be up to 30kV). Which I strongly advise people take into account, these things are dangerous without proper discharging. I do not advocate any Tom, D*ck or Harry doing something similar without prior experience or qualification of handling CRTs
In short. Do not replicate this idea yourself unless you are experienced or qualified to handle CRTs. Should you choose to make your own, PROCEED AT YOUR OWN RISK.
Now with that out the way
The idea behind this project is that as well as a PC enthusiast I am a very keen game collector, especially anything that predates the millennium. I love playing my original machines on TVs that were available at the time. So to me, hooking a SNES or MegaDrive up to a new TV is heresy. I want to be able to play different consoles on my old TV without having to change console constantly because I don't have space to have multiple consoles out at a time, otherwise I would. So that's where this comes in.
To the gear that will bring this to life
Raspberry PI 3 Model B
Raspberry Pi Power Adapter
Pi Supply Switch
3.5 RCA Jack to Composite Cable
128GB MicroSD Card
Green LED Momentary Switch
Red LED Momentary Switch
Red non-LED momentary Switch
Male to Female USB Type A 30cm Cables
Raspberry Pi Heatsinks
Noctua NF-A4x10 5V 40mm Fan
That is all the stuff I can readily buy, I will still need a few things custom made which I will be designing and sending off.
Here is the TV in question, it's a little Daewoo 14 inch with a VCR built in
Before I can do anything, I gotta get it open to get plenty of measurements and things to avoid which was fairly easy, 2 screws at the top and 2 at the bottom and the whole back slides straight off revealing the old dusty guts which I couldn't resist wiping to see how dusty it is, but it is nearly 20 years old, so it could be worse!
I've hit jackpot with this TV for two things, The flyback transformer (That holds that huge voltage) is on a different circuit to the main motherboard, and mounted no where near it! Still though, gotta avoid touching it even after discharging it, same goes for the anode that is connected to the CRT
Jackpot reason two, the TV's motherboard is secured to a base that just slides out case which will make my life a hell of a lot easier, and safer!
After 20 minutes of being very careful I got the old VCR removed, who knew how many different parts they would have? I expected unscrew the base and it comes out as a unit, but nope, had to remove it bit by bit.
Since I've got it all out, I can begin measuring, I want to use the old screws and mounts the VCR used for the PI but it leaves a huge gap in the middle which can bow and bend, so I'll be adding legs that will sit on the blank parts of the motherboard. The other thing I'm measuring is the VCR's slot, which I will turn into the controller ports as well as the power switch.
Both of these are being worked on now and will add an update in a week to give you all an idea of what they will look like!
Pi Supply Switch
128GB MicroSD Card
