Versions of the same 7850
paulstung
I'm looking to buy a new gfx card to add to my loop . I'm a little confused to the different models of the same card as in the boost / oc versions . I understand that there is no need to pay the premium for a fancy heatsink , cos it's coming off any way . But lets say one card is clocked at 800 and the model up is the oc is clocked at 925 . The card at 800 can be clocked to the same , it's just the oc version is out of the box factory over clocked ? Am I understanding that right ?
So if that is right for £40 less it makes sense to buy the standard version of the said card And just over clock it your self ? Or is it that the oc version is a more capable gpu ( cherry picked ? ) Have i just missed something all together ? I also understand to make sure of the right pcb for matching a block too . Cheers for reading guys.
For the most part they're all the same chips as most factory OCs are extremely conservative. Just make sure it's a reference design, or at least there's a block made for it, and you'll be fine.
http://www.coolingconfigurator.com/
Use the above website to give you an idea on what blocks are available for a chosen card, but bear in mind that it only takes into account one manufacturer (EK).
clocks don't matter, all that matters is that it's the same GPU. the clock speeds you can adjust anyways.
Cheers guys I thought as much ,I can save myself almost £50 now . I have a checked and double checked the EK configurator , whats going on with the blocks they had some sexy looking acetal / nickel nice and slick looking . But the newer ones are a big chunk of acetal with bloody circles all over it .
whats the point in watercooling a 7850? if you got enough money for a good custom loop you might as well spend some money on your gpu
