Hi,
I'm not sure whether anyone else has reported the issue previously, but I would be really grateful if an adminstrator who has access to the UT3 TDM #1 (212.69.36.85) could help with the following:
Over a month ago an administrator installed UT3 Patch 2.0 on the server which was done successfully, however, they did not enable Map Voting (only 1 map is available - Deck), and I am not sure whether they installed the UT3 Titan Pack which contains the latest official UT3 maps. Since then, the number of players on the server has dropped pretty badly.
Would it be possible for someone to look at the above? The UT3 Titan Pack is available at the official UT3 site and Beyond Unreal. It should also be fairly straightforward to enable map voting again.
Many thanks for your help.
