UT3 - Coming in November!
I don't know about every1 else, but the quality of that vid was a bit poo?
It does look pretty awesome though! Must upgrade the PC for that mofo :p
name='XMS' said:
We _should_ have a sneak preview of this next week :D
As the mods have said already, they'll have to drag XMS out kicking and screaming when the demos over.
It was yeah.. and ooo hit me up if you are, i may buy that 7800 back:D
They ain't even gonna get to do the demo! The second that UT3 disk makes an appearance I'm gonna slide across the table, rip it out their hands and jump out the window :p
woooo, that does look good.
/me goes to check the req specs
I'll paste what a quick google found regarding specs (from what i can the below artical was posted in 2005)
UT3 Graphics evolution
The most visible technological improvements in UT3 come from the move to Unreal Engine 3. Environments now spring to life with rich shaders, and per-pixel lighting. All those fancy pixel programs require atleast a DirectX 9 compatible graphics card to be run at all.
First words on UT3 requirements
We have preliminary system requirements for UT3 which according to the german gaming magazine PC Games Hardware comes from a source inside Epic Games. The Requirements are very high by todays standard, but hardware has got some time to get better & cheaper before the games estimated release in 2007.
Epic on hardware requirements 2007-05-29:
Generally speaking, the game runs quite smooth with DX9 hardware released by NVidia and Ati since 2006. On high-end cards, including the DX10 models, UT3 runs incredibly smooth already. Additionally, we also support shader 2.0 graphics hardware, with only a few technical limitations.
It will be intresting to see benchmarks from UT3, to see how much processing power the Unreal Eninge 3.0 will require from our CPU's and graphic cards.
Preliminary UT3 System Requirements
Minimum Requirements
CPU: 2.8Ghz
RAM: 512MB
Graphics: Geforce 6 series
Recommended System
CPU: 3-4Ghz
RAM: 1024MB
Graphics: NVIDIA 6800GT/Ultra or 7800GT/GTX SLI
UT3 Technical features and requirements
* Dual-core CPU: Multi-threading is supported and should provide much better performance
* 64-bit version to be available with better textures
* Renderers: SM3.0, 2.0, possible DX8 renderer
* HDR supported
* Physics: Novodex Physics Engine
* AGEIA PhysX PPU supported.
Keep in mind that these are not official requirements from Epic, nor final. What we know is that the game will take advantage of technologies such as dual core processors, AGEIA compatible Physics chips and Shader Model 3.0.
Thilo Bayer, Editor-in-Chief PCG Hardware, adds:
As I clarified in a seperate e-mail with Mark Rein, we have some misunderstanding in the term "minimum specs". We mean "minimum specs for high in game detail" which is not the same as bare "minimum specs" so that the game runs at all.
Statements from Epic about requirements & performance
At E3 2005, Epic's Tim Sweeney suggested an NVIDIA GeForce 6800 Ultra level card for decent frame rates at 1024x768 resolution.
According to Mark Rein, VP of Epic, Nvidia 7800 GTX runs Unreal Tournament 3 significantly faster than the Geforce 6800 generation of cards.
ok what gets me is.. this is DX9 right?.. what does that say to you?
8800's shown wipe the floor with this right?
or is it DX10 i can't remember
i'm so getting a physx card for this
I think it's both dx10 and dx9
Nope its straight up DX9. This game was created on a 6800ultra if i remember correctly. Or that could have been hxc rumour, idk. But i DO know this is DX9 and multi-threaded. I would say, if you have a 7900 or above card you should be more than plenty fine. (With 2gig of ram ect)
I thought they put the date forward by 3months because of the DX10 stuff they were adding to it?
I'm pretty sure they did as a lot of people were asking if it was going to be DX10 only.
edit: http://blogs.nvidia.com/developers/2007/05/ut3_to_be_direc.html
nvidia said:
May 10, 2007
More good news, I just had lunch at Vesuvios here with Mark Rein and he confirmed that we can now come out and say that Unreal Tournament 3 will be DX10 and in "The Way Its Meant To Be Played" program for launch.
i can see how it would make full use of the PPU of a physx card from the liquid and explosions and stuff i want this game SO bad
