Uploading my site to my ISP
Hyper
Hello All
I currently run www.northernrc.com and want to move it to my isp's server as they provide me with 250mb web space. This includes 1 mysql database.
So i have made a backup of my current mysql database and its a gzip file but i havent got a clue on how to upload it to the plusnet server.
I go into my website settings inside the plusnet control panel and click on mysql and get phpmyadmin (dont have a clue how to use this)
Look at the attached file to see what i see.
Also plusnet give you a guide of how to use it but even though i have been hosting websites for nearly a year now this is totally new to me.
Take a look
If anyone can explain to me how i will get my full site onto there servers i would be very happy :D
Thanks Sam
Tiz quite easy mate, just download your entire site to your computer, login to your new servers FTP and then upload it all.
What about the mysql database though?
Hrmmm that sucks, the only way I could help you would be throuch cpanel as I know my way around it pretty darn well.
What you need is Jim or Dave's expert advice, they can probably get you up and running in no time at all.
Cheers.
Well you need to activate your mysql from control panel > website settings.
Although i dont have plusnet account i have managed to login with my old details and i cant see that option there. Maybe its because of my account type ( pay and go )
Once you enable mysql you should receive an auto email with mysql details.
Their usual mysql server was rumpus
login name = username
databasename = username_pn e.g username_pn
password= auto generated when u activate your mysql.
You should upload your mysql file to your server root and ask them to import the data to your database, this is the best option and time saving otherwise depending on your database size you will need to create multi parts file as php might timeout , or it used usually time out when i used plusnet.
Make sure your tables and data are in a txt file and save it as filename.sql
select your database from phpmyadmin, on the right you ll see SQL on the menu. when you click on it it has 2 section , 1 section for quick commands and another for file , click browse then browse to your file and that should do it. Like i said if page timeouts divide your file in multiple files and import them 1 by 1. or eventually you can copy and paste into quick command box and apply part by part.
download.php
