deadplant1
Im plugged into router with ethernet cable with my desktop cant get it to connect to internet. Laptop will connect to the internet no problem. This is what ive got for ipconfig/all. I have tried to use a few of the tips i found on the internet but none of them have solved it for me please help!!!
Windows IP Configuration
Host Name……….. : grooveboxIV
Primary Dns Suffix . . . . . . . .
Node Type . . . . . . . . . . . . Hybrid
IP Routing Enabled . . . . . . . . . No
WINS Proxy Enabled. . . . . . . . No
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . :
Description . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address . . . . . . . . . : 94-DE-80-0F-F6-DB
DHCP Enabled . . . . . . . . : Yes
Autoconfiguration Enabled . . . . . . . . : Yes
Link-local IPv6 Address . . . . . . . . : fe80: :2023 :a3c6 :c6 :c813 :d11f%12(Preferred)
Autoconfiguration IPv4 Address . . : 169.254.209.31 (Preferred)
Submet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . :
DHCPv6 IAID . . . . . . . . . . . : 261414528
DHCPv6 Client DUID . . . . . . . . : 00-01-00-01-19-5B-E6-E3-94-DE-80-0F-F6-DB
DNS Servers . . . . . . . . . . . : fec0:0:0:ffff: :1%1
fec0:0:0:ffff: :2%1
fec0:0:0:ffff: :3%1
NetBIOS over Tcpip . . . . . . . . . : Enabled
Tunnel adapter isatap.{7D&23217-963f-4728-A4D9-E7AEC4C72694}:
Media State . . . . . . . . : Media disconnected
Connection-specific DNS Suffix. . . . . . .
Description . . . . . . . . : Microsoft ISATAP Adapter
Physical Address . . . . . . . : 00-00-00-00-00-00-00-E0
Autoconfiguration Enabled . . . . . . : Yes
fec0:0:0:ffff: :2%1
fec0:0:0:ffff: :3%1
