Iv just ordered some tygon 1/2" tubing but they have no stock! he offered me the Dangerden Clearflex60 1/2" how much better is Tygon? Or will the dangerden stuff be fine?
Doubt there is much difference TBH can't say first hand though, i was ging to get Tygon but went for the XSPC Stuff which is amazingly flexible. Easy to cut and ALOT cheaper.
Something like £3 per foot for Tygon or £3 for 3 metres of XSPC.
A thread on the WatercoolingUK forum had a photo of Tygon and XSPC tubing that had been in the same loop for the same length of time. The Tygon was badly stained and manky, the XSPC looked new!
If Tygon is harder to use and not as resistant to contamination, what is it that makes people say it's so good? Does it increase flow or reduce temps or such like?
