Transportation Settle Time
DaGuv
How long do you guys recommend letting a prommy MachII GT settle for before using after transportation?
The reason I ask is that I'm going to a small Lan Party a need to know if I have to get there early.
Cheers ppl. :)
Just going in the car you should be fine straight away, maybe an hour or so.
Its only really if posted its ideal to leave for 24hours due to insane amounts of movement
An hour for a car journey, try to keep the unit upright so there is as little mixing of the gas and oil as possible.
G
