Hi
I recently bought a Mach 2 GT from Ebay, unfortunately it wasn't packed too well, the inside of the compressor (?) was rattling a lot, made a mark on the side of the case bending it outside for example.
When I power the thing up outside the case with the molex and power cable connected, it slowly drops the temp every 2-3 mins so that it gets to about 14 degrees before the "to slow" error message appears. I've re-flashed it with no joy. When I switch it on I can hear gas? whilstling down the pipe and to the head.
Any advice gratefully received! I guess its probably stuffed. I'll try looking for leaks in the meantime!
P.S. The ebayer isn't answering any of my emails so I have no history.
Cheers
Drew
Cheers
Drew
