mayhem
Just got my TJ 07 last week wich had a pre-mod in the roof from ST.
Im just started tonight into looking how im going to fit in the rads which one was 3x120mm was supposed to be going in the roof but mah it didn't fit.
So im going to try and fit a 2 x 120mm in the base as well as a 3 x 120mm (both mayhems 4 pass Rev 1 beta rads)
Pics so far to start off with.
Full strip down and placement testing.
This build is nothing that gonna make your jaw drop im just moving my PC across from my box case to this because the box case is annoying the hell out of me.
