mikeyc33
Right ive been looking to do some overclocking on my cpu and know i have to set my memory in the bios so it doesnt fluctuate when i start tweaking voltages on the cpu.
My problem is this Ive been told to set the memory frequency to 1600mhz to allow a bit of leeway, yet in my bios its already set at 1600mhz and also looking at my memory the timings should be 9,9,9,24 Corsair Vengeance Black LP DDR3 12800mhz. Yet the timings are set 11,11,11,30 for some reason and this has thrown me on where to begin and where i should set these timings at in bios so the bios doesnt up them itself.
I've tried looking for my memory at Corsair and its not there for some strange reason. Here is the product code CM3B4G2C1600L9 so if anyone can advise me on why my timings are different thanks
http://www.dabs.com/products/gigaby...77-hd3--intel-core-i7-3770k---8gb-vengeance-l Capacity: 8GB (2 x 4GB Modules)
Speed: 1600MHz
Timing: 9-9-9-24
Type: DDR3
XMP: version 1.3
Format: DIMM
Pin Out: 240 Pin
Voltage: 1.5V
Speed: 1600MHz
Timing: 9-9-9-24
Type: DDR3
XMP: version 1.3
Format: DIMM
Pin Out: 240 Pin
Voltage: 1.5V
