BigIan88
So, I've been through what some may consider 'alot' of hardware in 2012 ranging from a change from AMD to Intel, at least 3 cases, 3 motherboards, 4 different kits of memory, 4 different cpu coolers, 5 GPU configurations, custom water cooling, 2 sound cards, 3 PSU's, 2 mice, 3 keyboards, 5 monitors, 2 headsets & 2 speaker systems.
To put an end to all of this change (which has been fun but quite an expensive venture!) i'm looking to put together one build, that im totally happy with to see me through the duration of 2013 with very little change - this is where you guys come in.
I have an idea in mind, which I now realise isnt exactly unique but im hoping the way I execute it and make some subtle customisation options - set it aside from similar builds.
To achieve the build I want, I need to spec a system that not only looks the part but has the horsepower to achieve the high performance I expect from investing such money in a PC.
My set up is currently:
CPU - i5 2500k
Motherboard - Asus Maximus Extreme IV P67
Memory - 16GB Custom Mushkin Ridgeback 2133Mhz
Storage - 256GB Crucial M4 SSD , 2x 2TB WD Green
GPU - HIS 3GB 7950
PSU - 1200W Coolermaster Silent Pro Gold
CPU Cooling - Antec Kuhler 620
Case - Corsair Vengeance C70
Monitor - 27" Asus VE278 LED
Mouse - Logitech G9x
Keyboard - Steelseries 6Gv2
The idea I have in mind, is as follows:
CPU - i5 3570K
Motherboard - MSI Mpower Z77
Memory - 16GB Mushkin Radioactive 1600mhz or 16GB Geil EVO Corsa 2400mhz
Storage - 256GB Crucial M4 SSD, 4x 2TB WD Green
GPU - MSI 7970 Lightning
CPU cooling - H100i or custom water cooling (again)
Case - Corsair Carbide 500R (Acrylic painted to match the yellow memory & with black racing stripes down each side panel, diagonally)
Mouse – Recommendation required – must have a little yellow in its colour
Keyboard - Recommendation required – must be mechanical and not have macro keys to the left.
Codename: Bumblebee
</SPAN></SPAN>
I have already bought the case and some Corsair SP 120mm fans (I will spray the removable inlet yellow). After xmas I will be looking to sell off most of my current build and sourcing the new parts ready for this project. I anticipate this will take until the end of February to complete due to xmas and January bills so I will be visiting this thread quite frequently.
Is there any advice, recommendations or changes you can offer?
CPU - i5 2500k
GPU - HIS 3GB 7950
CPU - i5 3570K
Codename: Bumblebee
