Three hours of OCCT?
Cheers linpack regular version do you have a link to the right one
I see why you are confused now, I wrote it sort of weird.
I meant the OCCT: Linpack test. The "regular one" I mentioned is just the standard non Linpack OCCT test. You have both, just select which tab at the top inside the UI:)
Thats what i thought you meant but was not sure thanks again :cool:
One last thing is that with avx and all cores ticked
You don't need AVX. You're using an i5 6600k. So by default/automatically OCCT will untick it for you. Don't enable it as I think the Devs said it will hurt your CPU.dont know if it's true but rather not risk it. Keep all cores ticked
