Right guys and girlies, I should be a cosmos 2 case and thought about going watercooling too only a preliminary setup i may not actually go with it depending on finances.
This would be my first time with watercooling as well, so I initially thought of going for the xspc rs360 kit because of toms review with Mayhems aurora nebula blue but then realised these are incompatable due to the pump being in the res. So then started looking at other options like thicker rads then realised can't go 60mm thick rads so now am looking at:
xspc EX360 rad
xspc Raystorm cpu waterblock - look so cool
xspc 5.25" single drive bay res
Laing DDC -1+ Ultra pump (MCP355) with phobya 1/4" top or the phobya DC12-400
Bitspower 1/4" Thread Barb Fitting for 1/2" im not sure how many of these i will need and the right size depending the pump (i think) lol
Masterkleer Hi-Flex 7/16" ID - 5/8" OD (11-16mm) Tubing : Clear
then 3 120mm bitfenix spectre blue fans or the pro ones
Mayhems Aurora Nebula Blue
this is what ive got from reading other posts and guides and oh yeah im just looking at cooling the cpu at the moment, not sure where i would mount the pump either as i was hoping to use res with the pump inside but i would rather have the liquid. So if anyone has any other reccomendations or tips would be a help and my budget is £250max but i would prefer the £200 mark thanks
My other options i was thinking of was just to buy the h100 or the nh d14 but that kinda seems like the boring option lol
or the xspc raystorm 750 ex360 kit from specialtech with either mayhems pastel blue or x1 blue be better option? i just really like the aurora range
http://specialtech.co.uk/spshop/cus...oling-Kit--EX-Series-Kit-Intel-pid-14807.html
xspc EX360 rad
