Mr. Smith
If you are in the market to buy a new air cooler for your rig, you could do a lot worse than Thermalrights revised 120, the Extreme version, now with 6 pipes instead of 4!
Theare are a few teething problems (mounting is now requires a bit of modification) with the new design which Thermalright will undoubtedly iron out before releasing.
Temps are improved and OC'ing a X6800 was stable at 3.940GHz - on air! Add another fan set to push/pull configuration and you have a real winner...
Read about it here
Read about it here
