Something to keep in mind, is that it's only at boot that you'll usually have any issues...
When you boot at -10 to -15 your cpu temp is at that temp when it boots, but within the first second the temp rises dramatically whatever the temp reading of the cooler is...
Your cpu temp will be anywhere from 15-25 degrees higher than the display shows, depending on what tim you use, the integrated heatspreader, high/low load, etc, so it's usually only at boot you have issues, unless you're using a really powerful cooler...and even then, you can up the vcore to bring the low load operating temp of the cpu up to prevent any cold bug issues, as well as turning off 'cpu disconnect' to keep that little bit of load on the cpu...
you'll know pretty soon where you stand, but keeping that in mind, you should be fine...
there's a load chart on asetek's site that's really handy for both Mach's and Vapo's so you can extrapolate the cpu temp from the cooling system's control unit temp reading...
It's likely not 100% perfect, but a good guide to where you stand...
Gray
