The Official OC3D Vape Bar
I understand that but we "may" have new legislations coming in on the 20th may as i'm a guy that was addicted to nicotine at 15 I would say the fuhrer's are out to get us and tax more fella
Government loosing to much tax from people not smoking they want us back on the tobacco, if they make it so you can only have the crap e-cigs then I'd go back to normal cigarettes e-cigs never worked for me.
All I can see happening is a less safe less controllable market opening, like the importing of tobacco is now
Well my Eleaf Ijust 2 arrived yesterday and my Heisenberg fluid.
Been using it since 2pm yesterday and it's pretty good, decent flavour, decent throat hit and decent vape production.
The one thing I don't like is the fluid seems to be quite hot and burns my throat abit so looking, in to it and going to try some different fluids.
I wish I could but it doesn't have voltage control.
Looking in to getting a mod when I have the cash but I'm getting lost in it all and trying to find a decent site to buy stuff from.
how much are you looking to spend, could recommend a few mods?
I don't know yet I need to see what I have left when I next get my money, which isn't going to be alot so I might need to save up for 2 months, then look at what I can get.
Ideally I am looking in to something where I can swap the batteries out so, if the batteries die I can just pop in some new ones and charge the other ones.
I have the Innokin coolfire IV with an aspire nautilus Tank bought both from Amazon.co.uk
http://www.amazon.co.uk/gp/product/B00ZNOEHV6?psc=1&redirect=true&ref_=oh_aui_detailpage_o05_s00
I would recommend the Nautilus mini as it's better than the Original
http:/http://www.amazon.co.uk/Aspir...55175292&sr=1-2&keywords=aspire+nautilus+mini
The coils are very cheap as well :)
http://www.amazon.co.uk/Aspire-Coil..._UL160_SR160,160_&refRID=12HXXQJNWTW7SDTJNFGP
I had a Nautilus tank, on my old Vamo V5 but my brother is using that.
I think what I will do is when, I have a decent amount of cash available to buy a new Mod and Tank then I will post back and see what people think I would be best getting.
I might even look at a tank where you make your own coils but need to think about that.
Ahh okey i'm sure the other Vapers on here will point you in the right direction if you want a mod where you can swap the batteries out. I can still use my mod even when it is charging which is a bonus :)
Yeah I can use this one whilst it's charging which is good, but I don't like not being able to change the batteries as they only have a small lifespan, really and with the price of some of these mods it's abit annoying that some of them cannot have the batteries changed, meaning you have to buy a new unit when the batteries die fully.
So I borrowed a Coolfire IV of a friend for a few days and it was good but the battery life was not great, so I got a Smok XCube II and some batteries for it cheap of a friend as he has gone to a DNA 200 mod and this thing is great.
My mate gave me a Innokin Isub G tank and I am using that on the Xcube at 25w and the vapour and flavour is great.
I decided to get a Smok TF-V4 and well my TF-V4 turned up and I have tried it over the weekend as it arrived on Saturday and wow what a mistake it was to buy it.
Tried the triple coil, quad coil and the rebuildable section and all 3 of them produce great vapor but produce no flavour at all.
Tried it at multiple different wattages and nothing helped, so I am going to use it as a spare when I am waiting for coils to turn up for my Innokin Isub G tank.
The other downsides apart from lack of flavour was battery life and juice usage, it was just stupid, I normally have to fill my tank roughly every 3 hours and change the batteries once a day, but with the TF-V4 I was filling it every hour and the batteries needed to be changed basically every 6 hours.
The batteries I am using are Samsung 18650 25R's and last a day basically with my normal tank.
My herakles is the same, great tank when it works, but either way it juice usage is insane, i could easily do 30-40ml in a day!
To get decent flavour from a TFV4, just close the drip tip airflow completely and get the dual clapton coil heads. With that setup the TFV4 has some of the best flavour in any tank. Obviously to take it to the next level hit the rba (the single/dual are best) section and build your own claptons :P
Well I tried it again today and it's just not giving flavor at all.
Soaked the coil and then let it sit in the tank, with juice in the tank for 1 hour, then put it on the Xcube and put it to 40w gave it a couple of puffs and there was no flavor there was just a taste of cotton.
Got the rebuildable section of it, put some fresh cotton on it and soaked it again and put it on the Xcube again at 40w and there was no flavor again.
I took the drip tip of the Isub G tank and put it on the TF-V4 and adjusted the air flow at the bottom of the tank and still nothing, it gave a decent amount of vapor but no flavor.
***Edit***
Got to get a different flavour of juice to try it, as for the last 2 days I have had no flavour taste from my juice despite changing coils or tanks, even trying my dads which uses the same juice has no flavour to me but my dad tastes the flavour on all of them.
I will get some different juice next week, and try it and see if I can taste it as I believe I am suffering from what some call "Vapors Tongue" which is currently not going away so maybe a change of juice flavour will help.
Maybe that will help with the TF-V4 tank as well since this only started since using the TF-V4 tank.
Where do people get there cotton from?
Looking to order some so that I have some ready for when my Gemini RTA turns up.
Cant recommend Muji pads enough, they are basicaly what you get in the 5-10 packs that some online stores sell you for a couple of quid that just turn up in a zip lock baggy.
Prefer them to the cotton bacon stuff, and its soooo much cheaper, gives you more options for wicking aswell as you can either just trim a 4-5m strip off or spread it out and roll it.
140(says 180 on the listing/image tho) for £6.50
http://www.amazon.co.uk/Makeup-Facial-Cotton-Unbleached-140pcs/dp/B00MYXSRAQ
@Kambo, keep an eye on the integrity of the threads on that tank on the mini volt and dont over tighten it, some juices will just eat into the plastic and they will end up stripping off sadly, happened twice to ones i got for my dad to try when he ended up smashing the glass on his subtank repeatedly :(
Just what i had out on the desk got some other kit kicking around, left to right.
Zolt mini + low pro RDA
RX200 + Griffin RTA
Modified to series Ground Zero "Trigger" mod + Velocity clone
Generic copper tube mod + Derringer
Brigada clone + Derringer clone
Cherry bomber clone + fishbone RDA (Kenedy comp. with glass cap basicaly)
Goblin mini with http://driptipsbybig.co.uk/ anti wobble replacement tip
Haze dripper tank (super nice but simple series/125-150w build on this HERE 20 wrap 22awg single wire "dual" coil)
Cigreen x-v3
Also just ordered a 30mm gold Temple RDA for some mess around giggles on the series box with some big builds i just cant fit inside regular 22mm drippers and so ill have something to use when i get around to picking up a 26650 tube mod and one of the new super nice 30mm VCMT RTA's, this thing is basicaly a full size 22mm velocity deck inside of a tank that holds 10-11ml of juice :eek: , roll on my daily dripper build of 9 wrap 24awg clapton inside a tank.
