[The Duality] [Dual System in a Frozen-Q Apex mATX]
New sponsor! Welcome to bequiet! who will be supplying me with 4 of their 80mm Pure Wings 2 fans! These fans are gorgeous!
Product Page
FileServer.php
Another new sponsor! This time it's Gigabyte with Two ITX motherboards! One for each system!
The motherboards
The Kaveri FM2+, ITX, GA-F2A88XN-WIFI along with the Skylake 1151, ITX, GA-Z170N-Gaming 5
Hey guys! Sorry for the lack of update the last week! I will be however, be on vacation next week so I hope I can make a great big update for you guys!
I got these much faster than I had expected! :O
Thanks so much Gigabyte ([@]GBT-MatthewH[/@]) for the help! Without you this wouldn't be as good! Without further ado, here they are! :D The Kaveri FM2+, ITX, GA-F2A88XN-WIFI along with the Skylake 1151, ITX, GA-Z170N-Gaming 5!
So I want to welcome Diginate.com to the party. They do all sorts of custom decals! Check them out! :)
Also got the BeQuiet! 80mm fans! They're beauts!
So, I had a bit of free time this morning, I had the chance to cut both rear panel SSD/2.5" HDD trays! I used my trusty dremel with a small end mill :) These are done 100% by hand.
Played around all afternoon with the cables, the red ones you see are the phanteks extensions, they are a bit thicker than the CableMod ones so they're hard to put in, but once they're in, they don't move, it's a bit of a trade off. I like it, but my thumb hates it. This is just a quick and dirty testing and preliminary cable management. I will need to get my Phanteks Power Splitter and PWM hubs back! :) Also two more fans to install eventually when the time comes!
So after almost a week of planning, I finally drew out the bracket that will be used to hold both Phanteks PWM splitters, I won't reveal much yet, but I will be, as always, recycling a piece of aluminium salvaged from a Case Labs tray!
Also, I will be attempting to mod the PWM splitters so that they only use power from SATA because currently they're made to draw power from the 4-pin connector and SATA combined.
I had trouble with my last power splitter, but Phanteks came through and is sending me another of their power splitters, which I should be getting shortly, this will help me advance in the project a bit more!
Once all of this is done, I will need to mod one of the Phanteks CPU coolers to fit on the Gigabyte Z170N Gaming 5 because there's a bit of inteference with the WiFi module.
Since I removed the motherboard tray, I will need to make something to keep the case square, this will be made with angled brackets place in the bottom corners. Paired with two full plexi windows, the case will be structurally solid again :)
Sorry for the long delay without any updates, after a lot of though, I bought myself a 3D printer, this will help tremendously with my build. Stay tuned for more! :)
