[The Duality] [Dual System in a Frozen-Q Apex mATX]
I've had quite the set back lately, but regardless, this build is far from done and the show must go on!
This that said, I've got CableMod on board with a set of PSU extensions and extra cable combs! Stay tuned ^^
This build is about to get a lot better too, but I won't say what yet ;)
So this is what a Case Labs XL-ATX motherboard tray looks ready to be mounted to another case and transformed into ITX :) One more of these to come possibly!
The top has a tab with a spot for two rivets initially, but I had to chop that down. Along with this, I brought the whole bottom of the tray and expansion slots up to the last expansion slots height. This, technically puts me at 214mm. Once I'm done the second one, this case will be dual ITX with both a removable tray. I'm keeping the trays up to the size of the CPU cutout on these trays for cable management. I'm also still debating of the orientation of both of these. I have the choice between both regular, both reverse or one of both and have windowed side panels on both sides.
The trays them selves are done, just a tiny bit of sanding left and the paint will come later on. The turquoise paint was only put on for drawing purposes :)
Alright guys, I need help deciding what layout I'll be using. I have my mind set on one, but I want to know what you guys think!
Figured you guys would be interested in a bigger update! 5 hours of work = a new rear I/O panel. Only a small detail left, bonus points to who ever finds it! Also a bonus of my helper, she sunbathes more than anything though.
Dust filters?
Might make some custom cut dust filters after the mod is completed.
So I started working on the front of the case, behind the P400's front panel. The front of this case will be turned into exhaust. A spot for both 140mm and 120mm fans for the top and bottom of the case. This is part one of the bracket I will be creating for the PSU and power splitter. The PSU mount I'm using is from a Bitfenix Prodigy M. The aluminium sheet came from one of the Case Labs trays I butchered. No sense in wasting that high quality aluminium! :)
Only fools don't change their minds! Changed the power splitter orientation along with salvaging more Case Labs trays!
I love this ruler, every modder seriously needs one!
And done! :) Only the mounting holes for the whole thing to the front panel and a better spacer for between the PSU and Power Splitter mounting plate!
So I'm back from a week of vacation visiting my family :)
While home, I was talking to my father about my current mod and he said he found a few years ago, 4 lengths of aluminium square tubing that if I could use them, I could have them. Ends up, I brought around 448"++ of square tubing (Yes, that's almost 40 feet) of thick square tubing. I had to cut them in around 32"+ lenghts to be able to bring them in the car. These should help me quite a bit in my build!
I might be able to make more progress this week, I've spent quite a bit drawing out the front panels cuts this afternoon, so that's what you should be seeing next :)
So, this is a huge tease of what's to come, I still have TONS to do, but the layout is visible. So will be everything. This will be the cable management of a life time but I've got a very good idea on how to manage it :)
