Dablgrew
Greetings ladies and gentlemen,
Been a silent visitor here for a long time but now looking to change that by sharing my ongoing project to upgrade my gaming battle station going triple screen and assembling my first water cooled rig. Any respectable build should have a name so I to call my new PC "The Red Pill" inspired by one of my all time favorite movies and the selected color scheme.
I have been putting PCs together for myself and family members since my university days (seems like yesterday, but it is not) but never done any modding or water cooling before.
Having had the good fortune being gainfully employed for a few years I thought it was time I treat myself a bit and build a new rig for the next generation of games without focusing on Min-Maxing for cost - performance as I have done on past builds.
So lets see how deep this rabbit hole goes starting with the parts to be assembled.
The Red Pill - Hardware
Fractal Design Define S (Window) case
Intel Skylake i7 6700K processor
Asus ROG Maximus VIII Hero motherboard
16GB Corsair Vengance LPX 2666Mhz (Red) RAM memory
EVGA GTX 980 Ti SC+ 2.0+ graphics card
Samsung 850 EVO 500GB SSD drive
EVGA SuperNOVA 850W G2 power supply
CableMod E-Series Red/Black custom cables
Cablemod E-Series cable combs
The Red Pill - Water cooling
EK-Supremacy EVO (CSQ) CPU block
EK-FC Titan X (Copper Plexi) GPU block
EK-FC Titan X Backplate (Black)
EK-RES X3 150 Reservoir
EK-D5 Vario Motor Pump
EK-XTOP Revo D5 - Plexi Pump Top
Alphacool NexXxoS XT45 360mm radiator
Alphacool NexXxoS ST30 280mm radiator
PrimoChill PrimoFlex Advanced LRT BloodShed Red 10/16mm (3/8”-5/8”) tubing
EK-ACF Red 10/16mm fittings
EK-CSQ G1/4 (Black) plugs
EK-AF Angled 45° G1/4 (Black) adapters
EK-AF Angled 90° G1/4 (Black) adapters
EK-AF Extender 8mm M-F G1/4 (Black) adapter
EK-Coolant EVO Clear coolant
Fractal Design Venturi HP-12 PWM 120mm fans
Fractal Design Venturi HP-14 PWM 140mm fans
The Red Pill – Lighting and Visuals
EK- 3mm Twin Ultra Red LEDs (CPU & GPU blocks)
Fractal Design R4 3mm red L power LED harvested from my current rig (modding ?)
EK-G1/4 Plexi Plug for reservoir
XSPC - 5mm Single Red LED
Black PCI covers from my R4 case to replace the white ones on the Define S case to keep the color scheme Red & Black.
The Red Pill – Displays, Audio and Desktop Hardware
EIZO FlexScan EV2450 monitors
DELL MSA 14 Single Monitor Arm Stands
Steel Series 6Gv2 Mechanical Keyboard
Steel Series Sensei Mouse
Cooler Master Storm Skorpion Mouse Bungee
Sennheiser PC 363D Headset
Scandyna Micropod SE Active speakers
Edit 151017: After getting hands on with the parts realizing how big the pump turned out to be I revised the loop plan to this.
Speaking of parts is the ”before” picture of the parts pile, and so far so good more pictures and updates soon.
Having started my build I came across a few issues requiring some adjustments.
Having found that the pump was larger than I had expected I thought I would share some dimensions for it here. While researching my build I did not actually find any dimensions listed for the pump combo I am using. Actually it is quite strange that EK would not list it on their webpage or documentation.
Dimensions for EK-D5 Vario and EK-XTOP Revo D5 (Plexi) Pump-Top combo.
Besides working on the loop routing I installed the 0.3mm thick jet plate in the CPU block to follow EK's recommendation for LGA -1151.
So now I will wait for my extra fittings to come in before pushing on with the project hopefully by next weekend.
- The plastic IO port and audio component cover on the motherboard had to be removed to fit the top radiator and fans. No big deal I heat sinks look better without the cover and airflow for them should also be better now.
- The pump is much larger than I had guessed so my first loop plan did not work. I have revised it and ordered a few more fittings to do execute on my revised plan shown above.
- Top diameter: 78mm
- Top+Pump Height: 69mm
- Pump+Holder Width: 89mm
