Duality92
❚❚ Diginate.com ❚❚
❚❚ bequiet.com ❚❚
❚❚ FrozenQPCMods.com ❚❚
❚❚ Gigabyte.com ❚❚
❚❚ CableMod.com ❚❚
❚❚ Phanteks.com ❚❚
❚❚ ModMyMods.com ❚❚
du·al·i·ty
do͞oˈalədē/
noun
1.
the quality or condition of being dual.
"the novel's deep duality about human motive"
2.
an instance of opposition or contrast between two concepts or two aspects of something; a dualism.
"the photographs capitalize on the dualities of light and dark, stillness and movement"
Gaming
- Intel i5 6600K - Delidded - 4.7 GHz @ 1.488v load
- Gigabyte GA-Z170N-Gaming 5
- G.Skill Ripjaws V 3200/16, 2*4GB
- Gigabyte GTX 1070 G1 Gaming
- ADATA SP900 m.2 256GB
- OCZ Vector 128GB
- Antec EDG750 80+Gold Modular PSU with CableMod ModFlex custom cable set and combs
HTPC
- AMD 7870K
- Gigabyte GA-F2A88XN-WIFI
- Kingston HyperX Fury 1866/10, 2*8GB
- Samsung 840 EVO 256GB
- Antec VP450 PSU
Common Hardware and water cooling
- Custom Frozen-Q Apex mATX case
- Frozen-Q resevoir
- 4 * Be Quiet! Pure Wings 2 80mm
- 4 * Phanteks PH-F140MP
- 1 * Phanteks PH-F120MP
- 2 * Phanteks PWM Hub (new revision)
- CableMod RGB 60cm LED
- CableMod light blue sleeved SATA cables
- Darkside White LED strips
- Phanteks Extensions, 24-pin and 8-pin (red/black)
- 2 * Alphacool NexXxoS XP³ Light - Acetal - Intel/AMD
- Alphacool NexXxoS ST30 240mm
- Alphacool NexXxoS XT45 280mm
- Alphacool NexXxoS GPX - Nvidia Geforce GTX 1070 M01
- Alphacool VPP755 EisPumpe
- Alphacool Eisdecke D5 Top - Plexi G1/4 - V.3
- 4 * Alphacool G1/4 Passthrough Connector - Black
- 4 * Alphacool Eiszapfen 3/8" ID x 5/8" OD Compression Fitting - Black 6-pack
- 10 * Alphacool Eiszapfen 45° Angled Rotatable Adapter Fitting - Black
- 10 * Alphacool Eiszapfen 90° Angled Rotatable Adapter Fitting - Black
- 4 * Phobya LEDready Twin 5mm Ultra-bright white 30cm - Black
- 20 feet of Mayhems 3/8"-5/8" (10/16mm) Ultra Clear Tubing
- Mayhems X1 UV Blue Concentrate 250ML
