So, so so so.
A mix of good and bad, I am all full of bad, but I was looking forward to getting this done.
Before the disappointment, here's some pics
Cool feature of this case is any side can be removed leaving the rest intact:
This was to allow me access to the Mobo:
I decided to put all the fittings in:
Then my *special* PCI 'bracket':
These will be trimmed down later, and a couple of nuts will hold the GPU in place at the top.
Mobo back in and pump tubed up:
Now for some BENDING:
Now here comes the disaster.....Heatgun is all European plug
My only eu->GB plug converter is for a shaver and fuse cannot take a heatgun, nor can a bigger fuse fit.....
Not to let that deter me, I went to the kitchen and used the hob
First 90 Degree:
Pfft, who needs a heatgun!!
wimps!!
then the real disaster struck.....
I was using the monsoon pipe cutter do-dad....and I can only go with "I'm a bit of a muppet" because I only went and cut through the bloody metal:
I'm not overly pissed off at breaking the guide, but I've gone and cut the tube wonky now
I can "Probably" fix it with sandpaper, and I have more tube:
But to be honest, that's me for today
missing fitting arriving tomorrow, I'll grab my sandpaper and a new plug, and go for a fresh start tomorrow.
Thanks for reading
