The Antec i5 Mini Project *Watercooled*
completed will have pics tomorrow
overclocked to 3.8ghz
core voltage 1.312v using AS5
running prime for around 1 hour
idle: 33-34
Load: 56
res/pump still has bubbles so once they go the temps should improve
My old results with armageddon
core voltage 1.312v @ 3.8ghz
idle: 37-38
load: 72-75
more pics
its currently very hot in my room so i tried getting 4ghz anyways and i did:
4ghz @ 1.36v
idle: 35c
Load: 65
ignore the 67c and 66c that's when i was drinking hot choclate next to the comp when the case was open
once i get more fans and put the 240 rad in push and pull the temps should go down.
armageddon temps @ 4ghz 1.36:
idle: 43C
Load: 83C and rising (Fail)
i was also able to get my ram to 6-9-6-24 @ 2000mhz
