Hello, I'm new here so I'll try to not make this long. As the first thread states:
I need this to keep me all good for about 5 years, mostly because this is a budget a lot over what I can afford (by this i mean I have an income of about 200 euro
) so I need this to be as good as it get's in that price range.
With that said this is what I think is ok, please help me with advice, pros, cons, anything that you think is acceptable.
All the best,
Deeds
• Where are you located? - Romania
• What is your budget? - 1900-2000 Euro
• Will you need a monitor, keyboard, and/or mouse included in that budget? - No
• Shall you be requiring an OS? - No
• What will you be using this rig for? - Everything from 3D animation, video edit to everyday use
• If gaming, what resolution will you be playing at? 1920 - 1080 and higher
• Will you be overclocking? - Probably
• Do you need a full build or will you be reusing some old parts? - full build
CPU:
i7-4930K
CPU Cooler:
Xigmatek CAC-SXHH6-U02 Aegir SD128264
Motherboard:
Asus Rampage IV Extreme (maybe Black Edition
RAM:
G.SKILL - DDR3 16GB ( 4x4GB ) RipjawsZ 2133MHz CL9 XMP
Hard-drive:
Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Video Card:
EVGA Nvidia GeForce GTX 770 Superclocked 2GB
Case:
NZXT Phantom 630 (Matte Black)
Power Supply:
Corsair Enthusiast Series TX850 V2, 850W, [80 Plus Bronze]
All the best,
Deeds
