Temps with Quad Core?
name='Pat123' said:
my core 2 duo has both cores always within 1-2 degrees of eachother.
Well there`s an easy test for u. Keep the thingy u`r using to read the temps on the screen and run something on only 1 of the cores that`s intense, like SP2004.
name='NoL' said:
It is possible that you are seeing the slightest inbalance in your mount. Try tightening one side, and you might see a temperature change.
You were absolutely right Nol.
I tightened the screw a lil more and although its not quite balanced yet, temps dropped on 2 of cores by a few degrees but made of the other cores got a lil hotter too, so I still need to play with it a little more to get the pressure more balanced out.
I didnt realise it was so sensitive to pressure.
Tryin to play around with it but its really hard to get all 4 cores around the same temps.
The lowest temp I got for one of the cores was around high mid 30s. The average core temps is around mid-40s
If I clean the loop and add some gd coolant I could prob get a lil bit lower.
How much would thermal paste affect temps? Just wondering... (I used the thermal paste which came with the QX6700 >_< just wondering if i should have used something else)
