Dicehunter
Resident Newb
So I went to access the task manager a few minutes ago and this message comes up, Never seen this happen before, Any insight would be appreciated -
Odd, I have task manager.. see. Works fine.
try running
Code:taskmgr
from the run window or the command line
Very helpful wraith
Says access denied![]()
HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System
HKEY_LOCAL_MACHINE\Software\Microsoft\Windows\CurrentVersion\Policies\System
HKEY_USERS\.default\Software\Microsoft\Windows\CurrentVersion\Policies\System
I'd give her the old Anti-Malware/Anti-Virus treatment, sounds like you're being locked out.
You sure you don't have a virus?
Jasper
I has your task manager!
£1,000,000 should cover it. Delivered back to you within 24 hours.
HA ! You are mistaken, You actually took a used blow up sex doll that once belonged to a leper !
Why do you have a used blow up sex doll that once belonged to a leper? :mellow:
Clearly you've never been to Amsterdam![]()
