This is my second liquid cooled PC and wanted to make it very clean this time. I went from a crazy disco theme to just black and white. Even the colored parts of the MSI Mpower motherboard anoyed me so I already removed the yellow part of the chipset heatsink and am still looking for a solution to remove or paint the yellow stripe on the VRM heatsink.
Specs:
Case: NZXT Switch 810 matte black
CPU: Delidded i5 4670k @4.7GHz (hammer-vice methode)
Motherboard: MSI Z87 Mpower
GPU: Inno3D GTX 780 (+290/250 with modded BIOS)
RAM: Kingston HyperX Beast 8GB @ 1866MHz
PSU: Cooler Master V1000
Storage: Samsung 840 EVO 256GB
CPU block: EK Supremacy Nickel-Acetal
GPU block: EK FC Titan Nickel-Acetal
Pump: EK DCP4.0
Radiator1: XSPC RX360 (Alphacool UT360 was sold out at the the only proper Dutch WC store)
Radiator2: Alphacool UT240
Fans1: 8x Corsair SP120 High performance
Fans2: 3x NZXT 140mm casefans
Reservoir: Bitspower 150mL Clear
Tubing: PrimoChill PrimoFlex Advanced LRT 3/8 ID 5/8 OD Crystal Clear
Fittings: Alphacool
Liquid: Mayhems Pastel Ice White
Fingerprints =D
Specs:
Pump: EK DCP4.0
Fittings: Alphacool
Fingerprints =D
