So since my desk build never reached fruition I decided to return to my trusted 900D case.
For those interested you can find the old build here.
http://forum.overclock3d.net/showthread.php?t=68070
Anyway, I obtained a nice simple desktop and some electronic legs that is a god send in my long painting sessions. Original plan was to transfer my desk build over to this but the dimensions were off and rather than start from scratch i figured I would return to my 900D.
The legs are outstanding and useful
Some components were sold such as motherboard, cpu and memory so I have been using "placeholder parts" until my other pieces arrive.
Just to give an example of the horror I have right now.
Spec:
CPU: Intel 4790k
Memory: TBD
Motherboard: ASUS Z97 Mark S
Storage: Samsung 850Pro 512gb, 840Pro 256gb
GPU: Nvidia reference 980Ti, SLI
PSU: Seasonic 850W ultra quiet
Cooling:
Res: EK X3 200mm Res with white top and bottom
Pump: 2x MCP35X with EK Clear acrylic pump top, Swiftech heatsinks
Radiator: EK Coolstream 480 PE, Coolstream 360PE
Fans: TBD
Fittings: Assorted Bitspower deluxe white
CPU Block: EK Supremacy EVO
GPU: EK FC Titan X clear acrylic blocks
Spec:
CPU: Intel 4790k
Memory: TBD
Cooling:
Fans: TBD
