SuperFlower has released a 1600W PSU with 80Plus Gold and Platinum and Titanium certification. Pricing is set at £224.99, £259.99 and £299.99 and the units receive a 5 year warranty.
SuperFlowrs latest PSU features a fully modular design, 140mm silent DBB fan, Japanese 105°C capacitors, ECIntelligent Thermal control system, a huge amount of connectors and single rail design.
Here is a guide on the specifications of the Titanium model.
Features
100% Full Modular Cabling Design For Easy Cable Management /
80 PLUS ® Titanium Certified, 92% 94% 90% Efficiency At 20% 50% 100% Rated Load
Full Range AutVoltage Detection Design 100V~240V (Active PFC)
Comply With ATX 12V. V2.2, EPS 12V. V2.91 & SSI EPS 12V. V2.92 Specification
Comply With Energy Star Standard & EuP (Energy Using Products) Regulation
Over Voltage Protection / Over Current Protection / Over Power Protection / Short Circuit Protection / Under Voltage Protection
Support All Intel/AMD Multi-Core CPU & ATX/BTX Compatible Motherboards
Support NVIDIA® SLI™ & ATI CrossFireX™ High Performance Graphic Card
More than 2,000 times On/Off test
Unleaded Green Materials with RoHS/WEEE Compliance
Perfect For Professional & High Performance Gaming System
Specifications
Dimensions: 150 x 86 x 220 mm (W x H x D)
Fan: 140 mm DBB(automatic control, semi-passive)
Colour: Black (power supply, fan)
Fully Modular Design
Efficiency: max. 94% (115V), 80 Plus Titanium certificate
Active PFC
3.3V: 24 A
+ 5V: 24 A
+ 3.3V & + 5V combined: 120 W
+ 12V: 1,599.6 W / 133.3 A
- 12V: 6 W / 0.5 A
+ 5VSB: 15 W / 3.0 A
Safety: cTUVus/TUV/CB/CE/FCC/C-Tick/BSMI/RoHS/CCC
Connectors
Connectors
1 x 20+4-Pin ATX12V/EPS12V
1 x 8-Pin EPS12V
x 4+4-Pin ATX12V/EPS12V
9 x 6+2-Pin-PCIe
5 x 6-Pin-PCIe
14 x SATA
5 x 4-Pin-Molex
2 x Floppy
Warranty: 5yr
Specifications for the Gold and Platinum units can be found at SuperFlowers official website Here
SuperFlower have stood out from the crowd lately and are featured in many of our systems, we released a review of the 600W unit this week which you can view Here which picked up the 'OC3D White Gold Award'. Will you be purchasing this huge 1600W PSU?
Source
Features
Specifications
Active PFC
3.3V: 24 A
+ 5V: 24 A
- 12V: 6 W / 0.5 A
Connectors
Connectors
1 x 8-Pin EPS12V
9 x 6+2-Pin-PCIe
5 x 6-Pin-PCIe
14 x SATA
5 x 4-Pin-Molex
2 x Floppy
Warranty: 5yr
Source
