Sub £30 headset.
JiggaHertz
Hola chicas!
Looking to invest £30 or so into a nice headset. Not looking for great soundquality as I have proper headphones and speakers for that. Mainly interested in them having decent mic quality, being comfortable and being functional (plus looking snazzy).
I have three choices so far:
Sennheiser PC 310:
They are £40 but I can get them for £20 with a voucher.
(http://hmv.com/hmvweb/displayProductDetails.do?ctx=280;0;-1;-1;-1&sku=980512)
Ozone Onda ST:
Nice looking, seem decent
(http://www.amazon.co.uk/Ozone-Gamin...1_4?s=computers&ie=UTF8&qid=1358204978&sr=1-4)
Plantronics 86050-05 Gamecom 380:
Most popular on Amazon and very attractive price
(http://www.amazon.co.uk/Plantronics...1_2?s=computers&ie=UTF8&qid=1358205018&sr=1-2)
Any comments/help guys?
I thought the sennheisers seemed a bargain as I can get them for £20 as they are 25% off in HMV and I have a £10 HMV voucher...? (down from £40)
Thanks boyyyyzzz
Just get a microphone.
Your headphones will be better than any headset for the budget.
I use one of these:
http://www.maplin.co.uk/multimedia-microphone-24698
You really don't need to spend any more for gaming and VOIP.
As for the HMV voucher, just go and spend it as fast as possible, considering the way HMV are going it'll be invalid within a couple of weeks. I have one too so I'm just gunna look for anything to buy in there.
Edit - seeing your last reply though - I'd take the Sennheisers...
You should try search the sennheisers on amazon if they have them, just to see the reviews. Then if you like what you read get them with your voucher from the other place.
I never owned any of the mentioned headsets, but I did use Creative HS800 Fatal1ty for the last ~ 3 years. Build quality was ok for that price, I liked the sound (was quite good for music as well) and they were very comfortable for me, although if you look at reviews some people say they couldn't wear them for multiple hours. Never got any complaints about the mic.
In the end the cable snapped because I got up while having my foot on the cable. :frown:
