Stupid math question
Hatman
A line is perpendicular to the line (x/3) + (y/4) = 1 and passes through the point (4,1).
Find the equation of the line.
Well, for me I think its simply (x/3)+1 and (y/4)+1 but really arent sure.
Thanks 4 help. Due to being a computer site some guys will be good with math ;)
What I would do is get y by itself, cause then you'll know the slope. Then you just do inverse reciprocal for the slope of the new line, and use the point-slope form
4/3*x+y = 4
y = -4/3*x + 4
New line:
y = 3/4*x + b (perpendicular is inverse reciprocal slope as WC said)
1 = 3/4*4 + b
b = 1 - 3 = -2
y = 3/4*x - 2
Yea figured I would... that's what happens when I'm in a rush. Usually I check such things in Mathcad etc but I was on my way out the door...
edited btw
Best way of thinking about an equation for a line that passes through a known point (a,b), is that you now know that at that point, when x=a y=b. You can put that back into the equation to find out what you want from it.
