I recently changed out the boot drive of my Dell Insprion 1764 for a 120GB kingston SSD. Cloned my old 500GB drive on to it and it boots up super fast and is all fine and dandy.
Took the old HDD and stuck it in one of these: http://www.ebay.co.uk/itm/350504345...X:IT&_trksid=p3984.m1423.l2649#ht_4839wt_1396
After formatting the drive, it is recognised in windows and i've transferred my itunes and movies and stuff to it and that all works fine.
Now, the problem i'm having is when i turn on my laptop with the storage drive plugged in, it goes to the screen with the DELL logo but the bar at the bottom only goes 3/4 of the way along and no further. I can't get in to BIOS or anything. If i pull out the hard drive (which is easy to do as its in place of the cd drive) it boots up as normal (and really fast thanks to the new ssd ;])
does anyone know anything i can do to fix this?
I've tried looking in the BIOS but as it's a dell, there's not a lot of options and as I can only get in to the BIOS with the HDD unplugged, I can't see any options for it.
any help would be much appreciated OC3D!
cheers
cheers
