Stock
name='Youngie1337' said:
Got settings yet Moogle :).
I appreciate your help very much mate.
Yep, it's no problem helping. You've yet to tell me your ram specs or show me a product page link to it :P
Right sorry for taking so long, I've been reading vigorously and I've come up with some settings for a 3GHz overclock.
You might notice that I haven't defined settings for other options and well that's because you can leave them as they are as these ones are the main ones to set. When you set these settings if your bios has a save profile function use it so you don't have to re-enter all the settings incase you need to clear your cmos due to the system not booting. Although with ASUS boards and I'm pretty sure your one has this, when the system fails to boot/POST it turns off (or you can turn it off it doesn't) then when started up the next time it runs at stock settings but remembers your bios settings so you can adjust.
Anyway set the settings below and then if the PC boots up great! Go into bios and just check how the CPU temp is. My Q6600 idled at 40c or so at a 3.6GHz. Now if the temps are okay to you exit the bios and proceed to booting to Windows. If theres a crash or a BSOD then it's unstable then put the settings back to stock (Save stock settings into a mobo profile too if you can) and then come back and post here. I don't think you'll BSOD but you never know. If you do manage to get into Windows then make sure you have a few tools/utils for testing your overclock.
CPU-Z
CoreTemp
or RealTemp
Prime95 x32
or Prime95 x64
HCI Memtest
Memtest86+
CrystalCPUID
Some of those tools you might not need (if you get a stable overclock quick) but get them anyway.
The first one you'll be using is Prime95 + CoreTemp/RealTemp + CPU-Z.
When you run Prime95 for the first time click right button (iirc) which says just stress testing. Then click the menubar and goto Advanced then tick Round off checking. That makes sure errors are detected and you'll see the Prime95 systray icon go red.
Now open CPU-Z too and check that your CPU speed is 3GHz and FSB should be 1333MHz (Add 1 more MHz to your FSB in bios for 1337MHz FSB :haha:). Also note that your Core Voltage in CPU-Z is probably a bit lower than what you set it as in BIOS. It's always like this and if you didn't enable LLC (Load Line Calibration) then it'd drop quite a bit when you put it under load. That's called VDroop and it's always best to minimize it.
In CoreTemp or RealTemp you can choose to have it log temperatures to a file just incase the PC shutsdown you can always go back and read what the last temperature was.
Once you have those 3 open goto Prime95 and click Options from the menubar and click torture test and it will bring up an choice box.
What I do is run Blend and then In-place large FFTs. I usually run each test for around an hour each because I try to find my max stable overclock, but if you've already got a set and feasible overclock chosen (Like 3GHz) then you can do a full run. I run it for around 6h-8h (overnight when I'm sleeping) so if you're sticking with 3GHz then do that. If you get it stable at that and want to try for higher then I'll help you with that later.
Anyway just start a blend test and watch the temp monitoring program. I don't let my cores go over 65c but the Intel Processor Spec Finder
says 71c is their limit. So within a minute or two the the CPU temp will settle a bit and not increase so much and if those temps are decent and you're happy with them you can leave Prime95 to keep testing. If the temps get a bit too hot for your liking then click Test from the menubar and choose stop or alternatively right click the Prime95 tray icon and choose stop.
I've gone on quite a few forums to see the voltages for certain Q6600 overclocks to get a general idea rather than starting from scratch trial and erroring it.
Anyway my hands are hurting here are the settings, you know what to do and if you don't ask me more questions before you go ahead and change your bios :wavey:
AI Overclock Tuner: Manual
CPU Ratio Setting: 9
FSB Strap to North Bridge: 333
FSB Frequency: 333
PCI-E Frequency:
100
DRAM Frequency: DDR2-800MHz
(Or choose the nearest but under this as we don't want to overclock the ram
because then you'll have 2 components that may be unstable and then it becomes
harder to verify which is at fault. One step at a time)
DRAM Timing Control: Manual
1st Information
CAS# Latency: 4
DRAM RAS# to CAS# Delay: 4
DRAM RAS# Precharge: 4
DRAM RAS# Activate to Precharge: 12
3rd Information
DRAM Static Read Control: Disabled
DRAM Read Training: Disabled
MEM. OC Charger: Enabled
AI Clock Twister: Auto
AI Transaction Booster: Auto
CPU Voltage: 1.30000
CPU PLL Voltage: 1.50
FSB Termination Voltage: 1.20
DRAM Voltage: 2.1
NB Voltage: 1.20
SBridge Voltage: 1.10
PCIE SATA Voltage: 1.50
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
CPU Margin Enhancement: Optimized
Advance CPU Settings
C1E Suppport: Disabled
CPU TM Function: Enabled
Intel SpeedStep Tech: Disabled
CPU-Z
CoreTemp
or RealTemp
Prime95 x32
or Prime95 x64
HCI Memtest
Memtest86+
CrystalCPUID
You're amazing babe!!
Just done it and thank you Moogle :).
This has worked great and it now says 3.0ghz :). The temps are idle @ 34c.
Much appreciated :), +reps if I can find it :D.
Genious! Write this down as a guide and get it stickied, so simple.
:worship:Moogle:worship:
Nice one :hands:
Now once you're happy it's stable you can either leave your memory as it is (If you can have it running at 800MHz) or overclock it a bit and test using HCI Memtest and Memtest86.
I'll try and create a full on guide when I do some overclocking of my own :D
PS - I see you went for the 1337 FSB :haha:
What you need to do now is get 3.2 by using an 8x multiplier and 400mhz bus speed. Try the vcore at 1.375 and work down.
Your RAM will then run at 800Mhz provided it's set 1:1. :)
Don't forget higher FSB = more heat but it's a linear increase (iirc). It's the voltages that make the heat increase exponentially. With the bad comes good too, and it's whether that good benefits you much or not. The increased FSB speed increases memory bandwidth/speed so depending on what apps you might use it might be good.
Anyway that said you could always try for the ubiquitous 3.6GHz overclock which will allow 1:1 ram ratio. It took me 1.45v (in bios, was a bit lower on the board) to reach 3.6GHz stable. The voltages aren't real high as Intel's voltage limit for a Q6600 G0 (and B3 for that matter) is 1.5v.
