Rob_the_scot
I just bought a Silverstone sugo sg03 such a sexy case
, after reading some reviews they kinda moan about the air flow of the case
well thing is I'm not building a high end system in the case its just a pc for older gaming and linux use
i3 3240 3.4ghz (ivy bridge)
ssd
gpu prob a 6850/6770 or at a push gtx 560
so I was wondering will the stock intel cpu cooler be fine or should I upgrade to summit like big shuriken 2 (cpu max height 82mm)
I have 2 different sets of noctua fans from other builds I can use for intakes
2 x NF-F12 or 2x NF-P12.
I know normally an I3 and a stock intel fan is fine but with reviews of this case I just wanted to double check with you guys.
ssd
