Starting Soon
Make sure you set it up to run -bigadv work units to maximize your points per day
Ta muchly, just reading a BIGADV guide now
Unless you have previously folded SMP with a passkey you will need to get a passkey and run 10 SMP work units before the bonus will be applied. If you need to run the 10 units it would be much faster to run just regular SMP2 and switch to -bigadv after finishing the ten WU's
Appreciate the advice SMP it is, from small acorns and all that
Forgot about that, good point
2 x 4 core servers now up and running, another 8 servers to build. Completed my first wu on my own rig last nite.
