Ok to make sure i havnt missed anything That i will need il list the Parts here
Bitfenix spectre Pro Fan's (3 for the Rad)
Phobya G-Changer V1.2 360mm Triple Radiator
Phobya Balancer 150 Reservoir Black Nickel
XSPC RayStorm CPU Waterblock
Laing D5 (MCP655) Vario 12V Pump for 1/2" ID Tube
Mayhems Aurora Fluid for Water Cooling 1 Litre : Nebula Blue
EK FC7970 Full Cover Waterblock for AMD/ATI HD 7970 Graphics Card : EN Nickel Plexi
XSPC 7/16" ID - 5/8" OD (11-16mm) High Flex Tubing : Clear (3 metres for just in case)
Swiftech Fill and Drain Port for 1/2" (13mm) ID
Bitspower 1/4" Thread Barb Fitting for 1/2" ID Tubing Matt Black
I need 9 Bitspower fittings right? (1 for the Full port to connect)
