Something wrong with the stats update ?!
SnW
Guys am i the only one having problems with updating or what it IS showing as updated
Now my last update is only 900Points what the herpfh
I always seem to have this problem and i always get the same projects and its linked to my account, just takes a knock on effect on my 24hour average
Def a stats problem as our team points for the last update were only 16K, we usually run 50 to 60K per update unless someone sends in a -bigadv WU.
Just great , i upgrade another FERMI GPU , what happens.. problems with FERMI GPU's
But that aside.. i have it installed please give as a free problem RUN !!!
Re: 171.64.65.64 GPU3 points gone missing
Postby yslin » Wed Dec 15, 2010 8:04 pm
Unfortunately we have lost the records for credits so re-crediting in this case is not possible. Really sorry.
Welcome to the Joy's of Folding
I ran sth. similar to FAH ( WorldCommunityGrid@BOINC ) for
2y200d active processing time and never, never, never ever had
no work to do...
Yeehaw!!! GTX260 FTW!!! :-D
Ok... how do you loose records... stolen by the cleaning lady?
I think Stanford is doing some server maintenance/upgrades ATM, so think things might be a bit of a mess for a while
Maybe its better to have a break for me.. i have 5 FERMI cards of which i hardly had any credit yesterday
Hmm maybe not such a bad idea as i have overclocking problems again had this a few times already ,
ones i put in a FERMI card in PCI-E slot 1 i can't overclock for snot anymore
EDIT anyone has a idea what this can be ? CMOS already done ! maybe a BIOS update ?
or maybe i should start a thread on its own ?
if there is a new bios for your mobo then try it (which mobo is it btw?)
is your psu up for the task?
check if there is an extra power plug on your mobo, it'll probably be near the pci-e slots
what pci-e mhz are you running? have you tried changing that to see if it makes any difference?
Is PCIe still at 100MHz? Try bumping it up to like 105, don't go any higher than that. I've seen that fix overclocking issues on some boards.
